SafeSky'sAfter interfacehitting is"TAKE designedOFF", tothe beapplication simplewill andautomatically user-friendly,display allowingthe pilotsradar to focus on their flight during operation.screen.
Stop
By pressing the map icon at the top right of the screen, you can switch to map mode. This view can give you a better awareness of the surrounding traffic (Situational Awareness). Similarly,Similarly, in map mode, you will have the option to switch back to radar mode. Switching to map mode does not stop the sharing of your position.
Expliquer
