Main screen
    Internet: indicates the status and activity of the internet connection. SafeSky: provides information about the last exchange with SafeSky servers. My Position: confirms if the mobile device's GPS is properly transmitting its position. <Navigation Software>: confirms the choice and connection to the selected navigation software in the application Settings.
    If one or more of your fellow pilots (included in your SafeSky fellow pilots list - see the Settings chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if you wish.
      Pressing "Reset" will return the application to its default settings. You can choose to enable or disable the display of grounded aircraft. The MAP filter interacts with the altitude of the aircraft displayed on the map.
      The RADAR filter is important as it provides the visible traffic range in relation to your position. For example, in this case, the radar-visible traffic will be within the range of -3,500ft / +3,5000ft relative to your flight altitude. The following three filters are:
        Aircraft: Filters the type of aircraft you want to be displayed. Transponder: Filters the types of transponders aggregated by SafeSky you want to be displayed, including ADS-B, ADS-L, ASTERIX, FANET, FLARM, FLYING NEURONS, FLYMASTER, INREACH, MICROTRAK, MODE-S, NAVITER, OGN TRACKER, PILOT AWARE, REMOTE ID (Recreational Drones), SAFESKY, SPIDER, SPOT, XC GUIDE, XC TRACK. This list of transponders aggregated by SafeSky is continuously updated. Airport: Filters the types of airports you want to be displayed on the map (Airport, Ultralight Base, Hydrobase, Gliders, etc.).
          Status:
            🟢 VFR (Visual Flight Rules) 🔵 MVFR (Marginal Visual Flight Rules)
            Cloud Base Altitude in feet
            Only the PREMIUM version allows you to create more than one aircraft.
            This section is where you can manage all of SafeSky's Settings. There is a dedicated chapter for it.
            Radar screen
            Expliquer map
