Radar screen
Nearby weather - METAR/TAF
Nearby weather is displayed dynamically as your flight progresses. You'll receive the following information:
- METAR station (ICAO code + name)
- Wind strength and direction: the red arrow tells you which direction the wind is blowing, depending on your trajectory
- My position: confirms if the mobile device's GPS is properly transmitting its position.
Change aircraft
If you are flying multiple aircraft, ensure you select the correct one in the SafeSky App. In case you forgot, you can switch aircraft during the flight by accessing the list of registered aircraft. Using the correct aircraft configuration is crucial to ensure the proper hexadecimal registration code is used.
If your SafeSky configuration is not linked to your hexadecimal code or registration number, there is a risk of your aircraft being detected twice. This can be confusing for both you and other pilots.
Modify background color
Depending on the outside brightness, you can select either a black or white radar background.
The center of the radar represents your position relative to the surrounding traffic, indicated by a green triangle. In map mode, your aircraft icon will also be green.
- Up to +/- 0.5 nautical mile, or +/- 1 km
- Up to +/- 1 nautical mile, or +/- 2 km
Go to map view
Traffic:
ShownIconsas icons representing the type ofrepresent visible aircraft,along withshowing their callsign and relative altitude compared to yourcurrent position in flight.position. For example, +04indicates thatmeans thetrafficaircraft is 400 feethigherabovethan your position,you, while -12 means it is 1,200 feet lower. -
Airports: Airports are
representedmarked with their ICAO code, runway surface type, and orientation. A dashed line indicates a grass runway,whileand a solid line indicates a paved runway.IfClickthere is a METAR station aton theaerodrome, click on itairport to displaytheMETARinformation.information if available. - AIP: TMAs,
CTRsCTRs, and other zones are shown aswatermarks. The aim iswatermarks togiveprovide pilots with familiar landmarks..
If traffic is too close to your position, an orange or red cone will precisely alert you ofindicate its position. An audible alert can also be configured if you are using a Bluetooth headset.
FREE Version
If you have opted for the FREE version of SafeSky, the radar will alert you by considering a protection radius around your position. The intensity of the alert will be adjusted according to the proximity of other devices. SafeSky worked in this way until version 2.
PREMIUM Version
In its PREMIUM version, SafeSky offers, since version 3, a brand new algorithm that takes into account proximity on the one hand, but also the velocity and direction of aircraft. The result of this new way of processing traffic is to reduce the number of alerts that are not real dangers, thereby improving safety. In circuit, this new algorithm is particularly effective!
If traffic is too close to your position, an orange or red cone will alert you to its exact location. An audible alert can also be configured if you have opted foruse a Bluetooth headset.
During alerts, the screen iswill frozenfreeze until the danger has passed, allowing you to ensure that the driver is concentratingfocus on the outsideexternal world and not on the application.surroundings. The zoom level iswill automatically adjusted.adjust.
FREE Version
In the FREE version of SafeSky, the radar alerts you based on a protection radius around your position. The alert intensity adjusts according to the proximity of other aircraft. SafeSky functioned this way until version 2.
PREMIUM Version
Since Version 3, the PREMIUM version of SafeSky uses a new algorithm that considers not only proximity but also the velocity and direction of aircraft. This reduces false alerts and improves safety, especially in circuit.
Traffic proximity alerts are both audible and visual. They can be intrusive if proximity is intentional, for example.example when flying in a squadron. In such cases, you can disable all traffic alerts. Click on the icon
to access the detailed menu below:
In this window, you cancan:
Deactivate all alerts for nearby aircraft for
a period of5 minutes. ByclickingClicking on the registration of an aircraft in the
list, youlist willcanceldisablethe maps onlyalerts forthethat specific aircraftselectedfor the duration of your flight.
Settings radarRadar view settings
Clicking on this icon gives you quick access to basic settingssettings, soallowing you canto easily configure the font size and type of illustration for the traffic display.
At the bottom of thisthe screen, the red "STOP" button allows you to end your flight and stop sharing your position.
