Radar screen
Nearby weather - METAR/TAF
TheNearby weather near you is displayed dynamically as your flight progresses. You'll findreceive the following information:
- METAR station
concerned(ICAO code + name) - Weather conditions (VFR-MVFR-IFR)
- Wind strength and direction: the red arrow tells you which direction the wind is blowing, depending on your
heading.trajectory - QNH from the weather station
- My
Positionposition: confirms if the mobile device's GPS is properly transmitting its position. - <Navigation Software>: confirms the choice and connection to the selected navigation software in the application Settings.
Change aircraft
If you are flying with severalmultiple aircraft, ensure you may have taken off withselect the wrongcorrect one.one Youin the SafeSky App. In case you forgot, you can changeswitch aircraft during the flight by accessing the list of registered aircraft. It is important to useUsing the correct aircraft configuration inis flightcrucial to ensure that you use the correctproper hexadecimal registration code foris registration.used.
Without being able to make the link betweenIf your SafeSky andconfiguration is not linked to your hexadecimal code /or registration number, thethere is a risk forof otheryour usersaircraft isbeing that they will see youdetected twice. This iscan notbe aconfusing situationfor thatboth improvesyou flightand safety.other pilots.
Modify background color
Depending on the brightnessoutside outside,brightness, you can chooseselect betweeneither a black or white radar background.
The centrecenter of the radar is, of course,represents your position relative to the surrounding traffic.traffic, This position is representedindicated by a green triangle. If youIn switch to map mode, your aircraft icon will also be green.
- Up to +/- 0.5 nautical
miles,mile, or +/- 1 km - Up to +/- 1 nautical
miles,mile, or +/- 2 km - Up to +/- 2 nautical miles, or +/- 5 km
Go to map view
FREE Version
If you have opted for the FREE version of SafeSky, the radar will alert you by considering a protection radius around your position. The intensity of the alert will be adjusted according to the proximity of other devices. SafeSky worked in this way until version 2.
PREMIUM Version
In its PREMIUM version, SafeSky offers, since version 3, a brand new algorithm that takes into account proximity on the one hand, but also the velocity and direction of aircraft. The result of this new way of processing traffic is to reduce the number of alerts that are not real dangers, thereby improving safety. In circuit, this new algorithm is particularly effective!
If traffic is too close to your position, an orange or red cone will alert you to its exact location. An audible alert can also be configured if you have opted for a Bluetooth headset.
During alerts, the screen is frozen to ensure that the driver is concentrating on the outside world and not on the application. The zoom level is automatically adjusted.
Traffic proximity alerts are both audible and visual. They can be intrusive if proximity is intentional, for example. In such cases, you can disable all traffic alerts. Click on the icon
to access the detailed menu below:
In this window, you can
- Deactivate all alerts for nearby aircraft for a period of 5 minutes.
- By clicking on the registration of an aircraft in the list, you will cancel the maps only for the aircraft selected for the duration of your flight.
Settings radar view
Clicking on this icon gives you quick access to basic settings so you can easily configure the font size and type of illustration for the traffic display.
