Nearby weather - METAR/TAF
  • METAR station concerned (ICAO code + name)
  • Weather conditions (VFR-MVFR-IFR)
  • Wind strength and direction: the red arrow tells you which direction the wind is blowing, depending on your heading.
  • QNH from the weather station
Change aircraft
Without being able to make the link between your SafeSky and your hexadecimal code / registration number, the risk for other users is that they will see you twice. This is not a situation that improves flight safety.
Modify background color
  • Up to +/- 0.5 nautical miles, or +/- 1 km
  • Up to +/- 1 nautical miles, or +/- 2 km
  • Up to +/- 2 nautical miles, or +/- 5 km
  • Up to +/- 5 nautical miles, or +/- 10 km
  • Up to +/- 10 nautical miles, or +/- 20 km
  • Up to +/- 20 nautical miles, or +/- 40 km
  • Up to +/- 40 nautical miles, or +/- 80 km
Go to map view
During the flight, you can switch from the radar screen to the map and vice versa by clicking on this symbol ToRadar_Plan de travail 1.png.
Explication-Radar_ecran-EN.pngThe radar will display the following elements:
  • Airports: Airports are represented with their ICAO code, runway surface type, and orientation. A dashed line indicates a grass runway, while a solid line indicates a paved runway. If there is a METAR station at the aerodrome, click on it to display the METAR information.
  • AIP: TMAs, CTRs and other zones are shown as watermarks. The aim is to give pilots familiar landmarks..
FREE Version
If you have opted for the FREE version of SafeSky, the radar will alert you by considering a protection radius around your position. The intensity of the alert will be adjusted according to the proximity of other devices. SafeSky worked in this way until version 2.
PREMIUM Version
In its PREMIUM version, SafeSky offers, since version 3, a brand new algorithm that takes into account proximity on the one hand, but also the velocity and direction of aircraft. The result of this new way of processing traffic is to reduce the number of alerts that are not real dangers, thereby improving safety. In circuit, this new algorithm is particularly effective!
If traffic is too close to your position, an orange or red cone will alert you to its exact location. An audible alert can also be configured if you have opted for a Bluetooth headset.
During alerts, the screen is frozen to ensure that the driver is concentrating on the outside world and not on the application. The zoom level is automatically adjusted.
Traffic proximity alerts are both audible and visual. They can be intrusive if proximity is intentional, for example. In such cases, you can disable all traffic alerts. Click on the icon StopAlert_Plan de travail 1.png to access the detailed menu below:
In this window, you can
  • Deactivate all alerts for nearby aircraft for a period of 5 minutes.
  • By clicking on the registration of an aircraft in the list, you will cancel the maps only for the aircraft selected for the duration of your flight.
Settings radar view
Clicking on this icon gives you quick access to basic settings so you can easily configure the font size and type of illustration for the traffic display.
