Nearby weather - METAR/TAF
Change aircraft
Without being able to make the link between your SafeSky and your hexadecimal code / registration number, the risk for other users is that they will see you twice. This is not a situation that improves flight safety.
Modify background color
Go to map view
FREE Version
If you have opted for the FREE version of SafeSky, the radar will alert you by considering a protection radius around your position. The intensity of the alert will be adjusted according to the proximity of other devices. SafeSky worked in this way until version 2.
PREMIUM Version
In its PREMIUM version, SafeSky offers, since version 3, a brand new algorithm that takes into account proximity on the one hand, but also the velocity and direction of aircraft. The result of this new way of processing traffic is to reduce the number of alerts that are not real dangers, thereby improving safety. In circuit, this new algorithm is particularly effective!
If traffic is too close to your position, an orange or red cone will alert you to its exact location. An audible alert can also be configured if you have opted for a Bluetooth headset.
During alerts, the screen is frozen to ensure that the driver is concentrating on the outside world and not on the application. The zoom level is automatically adjusted.
