Nearby weather - METAR/TAF
  • METAR station concerned (ICAO code + name)
  • Weather conditions (VFR-MVFR-IFR)
  • Wind strength and direction: the red arrow tells you which direction the wind is blowing, depending on your heading.
  • QNH from the weather station
Change aircraft
Without being able to make the link between your SafeSky and your hexadecimal code / registration number, the risk for other users is that they will see you twice. This is not a situation that improves flight safety.
Modify background color
  • Up to +/- 0.5 nautical miles, or +/- 1 km
  • Up to +/- 1 nautical miles, or +/- 2 km
  • Up to +/- 2 nautical miles, or +/- 5 km
  • Up to +/- 5 nautical miles, or +/- 10 km
  • Up to +/- 10 nautical miles, or +/- 20 km
  • Up to +/- 20 nautical miles, or +/- 40 km
  • Up to +/- 40 nautical miles, or +/- 80 km
Go to map view
During the flight, you can switch from the radar screen to the map and vice versa by clicking on this symbol ToRadar_Plan de travail 1.png.
Explication-Radar_ecran-EN.pngThe radar will display the following elements:
  • Airports: Airports are represented with their ICAO code, runway surface type, and orientation. A dashed line indicates a grass runway, while a solid line indicates a paved runway. If there is a METAR station at the aerodrome, click on it to display the METAR information.
  • AIP: TMAs, CTRs and other zones are shown as watermarks. The aim is to give pilots familiar landmarks..
During alerts, the screen will be frozen until the danger has disappeared, allowing the pilot to focus on the external surroundings rather than the inside. The zoom level will be automatically adapted.Radar Alerte(EN).pngStopSoundAlert.png
