Nearby weather - METAR/TAF
Change aircraft
Modify background color
Go to map view
Airports: Airports are represented with their ICAO code, runway surface type, and orientation. A dashed line indicates a grass runway, while a solid line indicates a paved runway.
ByIfclickingthereon the airport icon, more detailed information (radio frequency, runway length, nearest METAR, etc.) will appear in a dedicated window. Ifis a METAR stationexistsat theairport,aerodrome,aclickwindonbarbitwilltoindicatedisplay thedirectionMETARand strength of the wind.information. - AIP: TMAs, CTRs and other zones are shown as watermarks. The aim is to give pilots familiar landmarks..
