Nearby weather - METAR/TAF
Change aircraft
Modify background color
Go to map view
TheRadar radarrepresentation is represented byusing concentric circles indicatingincorporating the informationNORTH zoneposition, basedas onwell 4 different zoom levels (see above). Inas the "Settings",aircraft's course and the radar's largest radius (in our case below, 19NM). The radar can be configured in nautical miles (NM) or kilometres (kms).
