Nearby weather - METAR/TAF
  • METAR station concerned (ICAO code + name)
  • Weather conditions (VFR-MVFR-IFR)
  • Wind strength and direction: the red arrow tells you which direction the wind is blowing, depending on your heading.
  • QNH from the weather station
During alerts, the screen will be frozen until the danger has disappeared, allowing the pilot to focus on the external surroundings rather than the inside.Radar Alerte(EN).pngStopSoundAlert.png
Depending on your preferences, you can decide to switch from radar mode to map mode. This view can give you greater situational awareness. Similarly, in map mode you can switch back to radar mode. Switching to map mode does not stop your position being shared.
