Nearby weather - METAR/TAF
    METAR station concerned (ICAO code + name) Weather conditions (VFR-MVFR-IFR) Wind strength and direction: the red arrow tells you which direction the wind is blowing, depending on your heading. QNH from the weather station
    Press this button during flight if you find yourself in a situation that could lead to an emergency landing. Simply activating SAR will trigger a series of actions detailed in the "Settings" section.
    This feature is active in both the free and PREMIUM versions.
    If one or more of your fellow pilots (included in your SafeSky fellow pilots list - See the "Settings" chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if you wish.
    During alerts, the screen will be frozen until the danger has disappeared, allowing the pilot to focus on the external surroundings rather than the inside.Radar Alerte(EN).pngStopSoundAlert.png
    Depending on your preferences, you can decide to switch from radar mode to map mode. This view can give you greater situational awareness. Similarly, in map mode you can switch back to radar mode. Switching to map mode does not stop your position being shared.
