Radar Screen vs Map Screen
Depending on your preferences, you can decide to switch from radar mode to map mode. This view can give you greater Situationalsituational Awareness.awareness. Similarly, in map mode you can switch back to radar mode. Switching to map mode does not stop your position being shared.
