Traffic: Shown as icons representing the type of visible aircraft, along with their
call signcallsign and relative altitude compared to your current position in flight. For example, +04 indicates that the traffic is 400 feet higher than your position, while -12 means it is 1,200 feet lower. -
Radar Screen vs Map Screen
