If one or more of your fellow pilots (included in your SafeSky fellow pilots list - See the "Settings" chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if you wish.
During alerts, the screen will be frozen until the danger has disappeared, allowing the pilot to focus on the external surroundings rather than the inside.Radar Alerte(EN).png
Radar Screen vs Map Screen
Depending on your preferences, you can decide to switch from radar mode to map mode. This view can give you greater Situational Awareness. Similarly, in map mode you can switch back to radar mode. Switching to map mode does not stop your position being shared.
