Issue
Solution
Check your device's time settings:
- Go to Settings > General > Date & Time.
Enable automatic time setting:
Turn onEnsure Set Automatically is turned on. If it is already on, toggle it off and then back on tosynchronizeresynchronize your device's time with the network.
Verify the accuracy of the time:
- Compare your device's time with other devices to ensure it is correct.
