Issue
Solution
Check your device's time settings:
- Go to Settings > General > Date & Time.
Enable automatic time setting:
- Turn on Set Automatically to synchronize your device's time with the network.
Verify the accuracy of the time:
- Compare your device's time with other devices to ensure it is correct.
