Issue
Solution
  1. Check your device's time settings:
    • Go to Settings > General > Date & Time.
  2. Enable automatic time setting:
    • Turn on Set Automatically to synchronize your device's time with the network.
  3. Verify the accuracy of the time:
    • Compare your device's time with other devices to ensure it is correct.
