How it works?
The principle
SafeSky is a mobile application designed for sharing real-time in-flight traffic information. Using the GPS chip of your mobile device, the SafeSky appApp sends your position to our servers, which then transmit it to other users of the application.
The visual below illustrates thehow operationSafeSky of SafeSky:works:
The internet
In Europe, the internet coverage is generally excellent. Based on our data since our existence, SafeSky boastshas an 80% success rate for data transmission up to 5,000 feet. Although there may be occasional spots with no coverage, SafeSky will automatically reconnect once the connection is restored. Moreover, SafeSky's primary pilot base consists of pilots flying in E and G airspace classes, up to 5,000 feet AGL. Beyond that altitude, pilots typically operate in different airspace categories.
Border crossing necessitatesCrossing a changeborder ofrequires switching to a new mobile network operator, whicha isprocess referred toknown as roaming. ThereThis isusually results in a relativelybrief briefnetwork loss of network (of the order ofabout 1 or 2 minutesminutes) in general), the time foras the mobile to connectconnects to the new operator, justsimilar asto thatwhat ishappens thewhen casedriving isacross in the car.borders.
