How It Works?
The principle
EcoSystem SafeSky
Equipped with radio transmission.
  • Seen by other aircraft equipped with radio transmission device
  • See other aircraft equipped with compatible radio transmission device in the vicinity
  • Radio signal received by ground stations and sent to SafeSky's servers
Equipped with radio transmission devices and SafeSky (Mobile Internet).
  • Same as green aircraft
  • In addition share/receive traffic through mobile internet
  • See the majority of the traffic, radio and Internet
Equipped with SafeSky (Mobile internet).
  • Share and receive traffic through mobile internet
  • See all traffic using SafeSky AND traffic received by ground stations
The internet
In Europe, the internet coverage is generally excellent. Based on our data since our existence, SafeSky boasts an 80% success rate for data transmission up to 5,000 feet. Although there may be occasional spots with no coverage, SafeSky will automatically reconnect once the connection is restored. Moreover, SafeSky's primary pilot base consists of pilots flying in E and G airspace classes, up to 5,000 feet AGL. Beyond that altitude, pilots typically operate in different airspace categories.
