How It Works?
The principle
The internet
In Europe, the internet coverage is generally excellent. Based on our data since our existence, SafeSky boasts an 86% success rate for data transmission up to 5000 feet. Although there may be occasional spots with no coverage, SafeSky will automatically reconnect once the connection is restored. Moreover, SafeSky's primary pilot base consists of pilots flying in E and G airspace classes, up to 5000 feet AGL. Beyond that altitude, pilots typically operate in different airspace categories.
xxx
The offer
If you have opted for SafeSky PREMMIUM, you can also benefit from the GDL90 protocol and view this traffic in your navigation application (SDVFR, SkyDemon, ForeFlight, EasyVFR, ...).
