Testing with Postman
Accessing the Postman Workspace
To get started with testing the SafeSky UAV API, you can access our fully configured Postman workspace with pre-built requests and authentication:
  1. Access the Workspace:
  2. What's Included:
    • Pre-configured API requests with HMAC-SHA256 authentication
    • Automatic signature generation using pre-request scripts
    • Sample request bodies and query parameters
    • Environment variables for easy configuration
Setting Up Your Environment
After forking the collection, configure your environment variables:
  1. Select the Environment:
    • In the top-right corner of Postman, click on the environment dropdown
    • Select SafeSky UAV API - Sandbox (or create a new environment)
  2. Configure Environment Variables:
    • Click the eye icon (👁️) next to the environment dropdown, then click Edit
    • Set the following variables:
    Variable Initial Value Current Value
    server https://sandbox-public-api.safesky.app https://sandbox-public-api.safesky.app
    ss-api-key (leave empty) <your_api_key>
    • Important: Set ss-api-key as a secret type variable to keep your API key secure
    • The Initial Value will be empty when you share the collection, while Current Value contains your personal API key
    • Click Save
  3. Verify Environment Selection:
    • Ensure the correct environment is selected in the top-right corner of Postman
    • The environment name should be visible (e.g., "SafeSky UAV API - Sandbox")
Understanding the Authentication
The collection includes a pre-request script that automatically:
  • Generates the required HMAC-SHA256 signature for each request
  • Sets authentication headers (Authorization, X-SS-Date, X-SS-Nonce, X-SS-Alg)
  • Handles timestamp generation for request bodies
  • Resolves environment variables in the canonical request
You don't need to manually configure authentication - just ensure your ss-api-key environment variable is set correctly.
Start Testing
Once the environment is configured:
  1. Select a Request: Choose any request from the collection (e.g., POST multiple UAV light - return traffic)
  2. Review the Request: Check the request body and query parameters
  3. Send the Request: Click Send
  4. View the Response: The API will return nearby aircraft traffic based on your UAV positions
Troubleshooting
If you encounter authentication errors:
  • Verify your ss-api-key is correctly set in the environment
  • Check that server variable points to https://sandbox-public-api.safesky.app
  • Review the Postman console for detailed error messages
