Testing with Postman
Accessing the Postman Workspace
To get started with testing the SafeSky UAV API, you can access our fully configured Postman workspace with pre-built requests and authentication:
Access the Workspace:
- Visit the SafeSky UAV API Postman Workspace
- Click Fork Collection to add it to your own Postman workspace
What's Included:
- Pre-configured API requests with HMAC-SHA256 authentication
- Automatic signature generation using pre-request scripts
- Sample request bodies and query parameters
- Environment variables for easy configuration
Setting Up Your Environment
After forking the collection, configure your environment variables:
Select the Environment:
- In the top-right corner of Postman, click on the environment dropdown
- Select SafeSky UAV API - Sandbox (or create a new environment)
Configure Environment Variables:
- Click the eye icon (👁️) next to the environment dropdown, then click Edit
- Set the following variables:
Variable Initial Value Current Value serverhttps://sandbox-public-api.safesky.apphttps://sandbox-public-api.safesky.appss-api-key(leave empty) <your_api_key>- Important: Set
ss-api-keyas a secret type variable to keep your API key secure - The
Initial Valuewill be empty when you share the collection, whileCurrent Valuecontains your personal API key - Click Save
Verify Environment Selection:
- Ensure the correct environment is selected in the top-right corner of Postman
- The environment name should be visible (e.g., "SafeSky UAV API - Sandbox")
Understanding the Authentication
The collection includes a pre-request script that automatically:
- Generates the required HMAC-SHA256 signature for each request
- Sets authentication headers (
Authorization,X-SS-Date,X-SS-Nonce,X-SS-Alg) - Handles timestamp generation for request bodies
- Resolves environment variables in the canonical request
You don't need to manually configure authentication - just ensure your ss-api-key environment variable is set correctly.
Start Testing
Once the environment is configured:
- Select a Request: Choose any request from the collection (e.g.,
POST multiple UAV light - return traffic) - Review the Request: Check the request body and query parameters
- Send the Request: Click Send
- View the Response: The API will return nearby aircraft traffic based on your UAV positions
Available Endpoints
The collection includes the following pre-configured requests:
- POST /v1/uav: Submit single or multiple UAV positions and retrieve nearby traffic
- GET /health: Check API health status
- Additional endpoints for various use cases
Troubleshooting
If you encounter authentication errors:
- Verify your
ss-api-keyis correctly set in the environment - Ensure the correct environment is selected in the top-right corner
- Check that
servervariable points tohttps://sandbox-public-api.safesky.app - Review the Postman console for detailed error messages
