Field (Req) Type Description
id (Yes) string The unique identifier of the UAV.
latitude (Yes) double Latitude in decimal degrees.
longitude (Yes) double Longitude in decimal degrees.
altitude (Yes) int Altitude (meters, GPS AMSL). Value -9999 means unknown.
altitude_accuracy int Accuracy level of the altitude coordinate in meters.
accuracy int Accuracy level of the horizontal coordinates in meters.
call_sign string UAV call-sign.
ground_speed int Current ground speed (m/s).
course int Direction of travel (degrees, clockwise from true north).
status string Status: INACTIVE, AIRBORNE, GROUNDED.
last_update (Yes) long Time of event in seconds since epoch (UTC-0).
turn_rate float Turn rate in degrees per second.
vertical_rate int Vertical rate (m/s): positive = climbing, negative = descent.
icao24 string Unique ICAO 24-bit address (hex string).
remote_id string CTA-2063-A Remote ID serial if your drone is eqquiped with Remote ID.
The Beacon model defines the structure of an aircraft beacon as provided by SafeSky.
id (Yes) string The unique identifier of the beacon.
ground_speed (Yes) int Current ground speed (m/s).
course (Yes) int Direction of travel (degrees, clockwise from true north).
beacon_type string Type (e.g., GLIDER, HELICOPTER, UAV, JET).
operation_area GeoJson Polygon for the area of operation (Advisories only).
remarks string Free text comment when applicable.
Example Payload
        "id": "my_advisory_id1",
        "latitude": 50.70716,
        "longitude": 4.36613,
        "altitude": 111,
        "last_update": 1764171645,
