| Field (Req) | Type | Description |
id (Yes) |
The unique identifier of the UAV. |
latitude (Yes) |
Latitude in decimal degrees. |
longitude (Yes) |
Longitude in decimal degrees. |
altitude (Yes) |
Altitude (meters, GPS AMSL). Value -9999 means unknown. |
altitude_accuracy |
Accuracy level of the altitude coordinate in meters. |
accuracy |
Accuracy level of the horizontal coordinates in meters. |
call_sign |
UAV call-sign. |
ground_speed |
Current ground speed (m/s). |
Direction of travel (degrees, clockwise from true north). |
Status: INACTIVE, AIRBORNE, GROUNDED. |
last_update (Yes) |
Time of event in seconds since epoch (UTC-0). |
turn_rate |
float |
Turn rate in degrees per second. |
vertical_rate |
Vertical rate (m/s): positive = climbing, negative = descent. |
icao24 |
Unique ICAO 24-bit address (hex string). |
remote_id |
CTA-2063-A Remote ID serial (Basic-ID) if your drone is eqquiped with Remote ID. |
The Beacon model defines the structure of an aircraft beacon as provided by SafeSky.
id (Yes) |
The unique identifier of the beacon. |
latitude (Yes) |
longitude (Yes) |
altitude (Yes) |
Altitude (meters, GPS AMSL). |
ground_speed (Yes) |
course (Yes) |
last_update (Yes) |
beacon_type |
Type (e.g., GLIDER, HELICOPTER, UAV, JET). |
operation_area |
GeoJson |
Polygon for the area of operation (Advisories only). |
remarks |
Free text comment when applicable. |
Example Payload
"id": "my_advisory_id1",
"latitude": 50.70716,
"longitude": 4.36613,
"altitude": 111,
"last_update": 1764171645,
