This is your UAV telemetry you are submitting to SafeSky.
| Field (Req) | Type |
id (Yes)
stringlatitude (Yes)
doublelongitude (Yes)
doublealtitude (Yes)
int-9999"9999 means unknown.
altitude_accuracy
intaccuracy
intcall_sign
stringground_speed
intcourse
intstatus
string
INACTIVE, AIRBORNE, GROUNDED.
last_update (Yes)
long
turn_rate
floatvertical_rate
inticao24
string2. Beacon Model
The Beacon model defines the structure of an aircraft beacon,beacon as provided by SafeSky, to represent and describe all detected aircraft in the vicinity.
This is the traffic returned by SafeSky.
id (Yes)
intaltitude_accuracyaccuracycall_signground_speed (Yes)
intcourse (Yes)
intstatus
string
last_update (Yes)
long
turn_ratevertical_ratebeacon_type
string
UNKNOWN(e.g., GLIDERPARA_GLIDERHAND_GLIDER, HELICOPTER, UAV, PARACHUTEMOTORPLANEJETAIRSHIPBALLOONGYROCOPTERFLEX_WING_TRIKESPARA_MOTORTHREE_AXES_LIGHT_PLANEPAVMILITARYSTATIC_OBJECT).
operation_area
GeoJson
beacon_typeADVISORYremarks
stringExample
Example
Payload
"id": "my_advisory_id1",
"latitude": 58.88228,50.70716,
"longitude": 5.51642,
"call_sign": "NOR303",
"last_update": 1764171642,4.36613,
"altitude": 283,111,
"altitude_accuracy"ground_speed": 0,
"course": 63,0,
"ground_speed"last_update": 71,1764171645,
"turn_rate"beacon_type": 0.06,"UAV",
"beacon_type"remarks": "HELICOPTER",Inspection "id": "478757"
"latitude": 50.72218,
"longitude": 4.615,
"call_sign": "LGL4EW",
"altitude": 6362,
"course": 108,
"ground_speed": 168,
"turn_rate": -0.06,
"beacon_type": "MOTORPLANE",
"id": "4D00C9"
"vertical_rate": 5,
"call_sign": "TEST UAV",
"transponder_type": "ADS-BI",
"last_update": 1764171644,
"altitude": 110,
"ground_speed": 10,
"id": "my_uav_001_l2TZ"powerlines"
