This is your UAV telemetry you are submitting to SafeSky.
string | Yes | The unique identifier of the UAV. |
double | Yes | Latitude in decimal degrees. |
double | Yes | Longitude in decimal degrees. |
int | Yes | Altitude of the UAV in meters, based on GPS altitude AMSL. Value "-9999" means unknown. |
altitude_accuracy |
int | No | Accuracy level of the altitude coordinate in meters. |
accuracy |
int | No | Accuracy level of the latitude and longitude coordinates in meters. |
call_sign |
string | No | UAV call-sign. |
ground_speed |
int | No | Current ground speed of the UAV, specified in meters per second. |
int | No | Direction of travel, specified in degrees counting clockwise relative to the true north. |
string | No | The current status of the UAV. Allowable values: INACTIVE, AIRBORNE, GROUNDED. |
long | Yes | The time of the event in seconds since epoch at UTC-0. |
turn_rate |
float | No | Turn rate in degrees per second. |
vertical_rate |
int | No | Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent. |
icao24 |
string | No | Unique ICAO 24-bit address of the transponder in hex string representation. See FAQs for more details. |
This is the traffic returned by SafeSky.
string | Yes | The unique identifier of the beacon. |
int | Yes | Altitude of the beacon in meters, based on GPS altitude AMSL. |
altitude_accuracy |
accuracy |
call_sign |
string | No | Beacon call-sign, available only if the pilot has a public profile. |
ground_speed |
int | Yes | Current ground speed of the beacon, specified in meters per second. |
int | Yes | Direction of travel, specified in degrees counting clockwise relative to the true north. |
string | No | The current status of the beacon. Allowable values: INACTIVE, AIRBORNE, GROUNDED. |
turn_rate |
vertical_rate |
beacon_type |
string | No | The type of the beacon. Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HAND_GLIDER, HELICOPTER, UAV, PARACHUTE, MOTORPLANE, JET, AIRSHIP, BALLOON, GYROCOPTER, FLEX_WING_TRIKES, PARA_MOTOR, THREE_AXES_LIGHT_PLANE, PAV, MILITARY, STATIC_OBJECT. |
operation_area |
GeoJson | No | When beacon_type is an ADVISORY, this GeoJSON represents the polygon for the area of operation. |
remarks |
string | No | Free text comment when applicable. |
Example
"latitude": 58.88228,
"longitude": 5.51642,
"call_sign": "NOR303",
"last_update": 1764171642,
"altitude": 283,
"course": 63,
"ground_speed": 71,
"turn_rate": 0.06,
"beacon_type": "HELICOPTER",
"id": "478757"
"latitude": 50.72218,
"longitude": 4.615,
"call_sign": "LGL4EW",
"altitude": 6362,
"course": 108,
"ground_speed": 168,
"turn_rate": -0.06,
"beacon_type": "MOTORPLANE",
"id": "4D00C9"
"vertical_rate": 5,
"call_sign": "TEST UAV",
"transponder_type": "ADS-BI",
"last_update": 1764171644,
"altitude": 110,
"ground_speed": 10,
"id": "my_uav_001_l2TZ"
