The UAV model defines the structure and attributes of an Unmanned Aerial Vehicle (UAV) as submitted to the /v1/uav endpoint. This is your UAV telemetry you are submitting to SafeSky.
altitude int Yes Altitude of the UAV in meters,meters based on (GPS altitude AMSL.AMSL). Value "-99999999" means unknown.
altitude_accuracylast_update intlong NoYes Accuracy levelTime of the altitude coordinateevent in meters.
seconds since epoch accuracy int No Accuracy level of the latitude and longitude coordinates in meters. call_sign string No UAV call-sign. ground_speed int No Current ground speed of the UAV, specified in meters per second. course int No Direction of travel, specified in degrees counting clockwise relative to the true north.(UTC-0). status string No TheCurrent current status of the UAV. Allowable values:status: INACTIVE, AIRBORNE, GROUNDED. last_update long Yes The time of the event in seconds since epoch at UTC-0. turn_rate float No Turn rate in degrees per second. vertical_rate int No Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent. icao24 string No Unique ICAO 24-bit address of the transponder in hex string representation.
The Beacon model definesrepresents all detected aircraft in the structure of an aircraft beacon as provided by SafeSky. This is the traffic as returned by SafeSky.vicinity.
latitude
double Yes Latitude in decimal degrees. longitude double Yes Longitude in decimal degrees. altitude int Yes Altitude of the beacon in meters, based on GPS altitude AMSL. ground_speed int Yes Current ground speed of the beacon, specified in meters per second. coursebeacon_type int Yes Direction of travel, specified in degrees relative to true north. status string No The current status of the beacon: INACTIVE, AIRBORNE, GROUNDED. last_update long Yes The time of the event in seconds since epoch at UTC-0. beacon_type string No Allowable values: UNKNOWN,Values: GLIDER, PARA_GLIDER, HELICOPTER, UAV, JET, etc. operation_area GeoJson No When beacon_type is an ADVISORY, this represents the polygonPolygon for the area of operation.operation (Advisories remarks string No Free text comment when applicable.only).
Example Payload:
        "latitude": 50.70716,
        "longitude": 4.36613,
        "accuracy": 3645,
        "call_sign": "ADVISORY TEST",
        "last_update": 1764171645,
        "altitude": 111,
        "id": "my_advisory_id1"
