altitude int Yes Altitude of the UAV in meters (GPS AMSL). Value "-9999" means unknown.
last_update long Yes Time of the event in seconds since epoch (UTC-0).
status string No Current status: INACTIVE, AIRBORNE, GROUNDED.
The Beacon model represents all detected aircraft in the vicinity.
beacon_type string No Values: GLIDER, HELICOPTER, UAV, JET, etc.
operation_area GeoJson No Polygon for the area of operation (Advisories only).
