The UAV model defines the structure and attributes of an Unmanned Aerial Vehicle (UAV) as submitted to the /v1/uav endpoint. This is your UAV telemetry you are submitting to SafeSky.
altitude int Yes Altitude of the UAV in meters, based on GPS altitude AMSL. Value "-9999"9999 means unknown.
icao24 string No Unique ICAO 24-bit address of the transponder in hex string representation.
The Beacon model defines the structure of an aircraft beacon,beacon as provided by SafeSky, to represent and describe all detected aircraft in the vicinity.SafeSky. This is the traffic as returned by SafeSky.
altitude int Yes Altitude of the beacon in meters, based on GPS altitude AMSL.
altitude_accuracy
int No Accuracy level of the altitude coordinate in meters. accuracy int No Accuracy level of the latitude and longitude coordinates in meters. call_sign string No Beacon call-sign, available only if the pilot has a public profile. ground_speed int Yes Current ground speed of the beacon, specified in meters per second. course int Yes Direction of travel, specified in degrees counting clockwise relative to the true north. status string No The current status of the beacon. Allowable values:beacon: INACTIVE, AIRBORNE, GROUNDED. last_update long Yes The time of the event in seconds since epoch at UTC-0. turn_rate float No Turn rate in degrees per second. vertical_rate int No Vertical rate in meters per second. beacon_type string No Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HELICOPTER, UAV, JET, etc. operation_area GeoJson No When beacon_type is an ADVISORY, this GeoJson represents the polygon for the area of operation. remarks string No Free text comment when applicable.
Example Payload:
        "latitude": 50.70716,
        "longitude": 4.36613,
        "accuracy": 3645,
        "call_sign": "ADVISORY TEST",
        "last_update": 1764171645,
        "altitude": 111,
        "id": "my_advisory_id1"
