The UAV model defines the structure and attributes of an Unmanned Aerial Vehicle (UAV) as submitted to the /v1/uav endpoint. This is your UAV telemetry you are submitting to SafeSky.
altitude int Yes Altitude of the UAV in meters, based on GPS altitude AMSL. Value -9999 means unknown.
icao24 string No Unique ICAO 24-bit address of the transponder in hex string representation.
The Beacon model defines the structure of an aircraft beacon as provided by SafeSky. This is the traffic as returned by SafeSky.
altitude int Yes Altitude of the beacon in meters, based on GPS altitude AMSL.
course int Yes Direction of travel, specified in degrees relative to true north.
status string No The current status of the beacon: INACTIVE, AIRBORNE, GROUNDED.
beacon_type string No Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HELICOPTER, UAV, JET, etc.
operation_area GeoJson No When beacon_type is an ADVISORY, this represents the polygon for the area of operation.
remarks string No Free text comment when applicable.
Example Payload:
        "latitude": 50.70716,
        "longitude": 4.36613,
        "accuracy": 3645,
        "call_sign": "ADVISORY TEST",
        "last_update": 1764171645,
        "altitude": 111,
        "id": "my_advisory_id1"
