The UAV model defines the structure and attributes of an Unmanned Aerial Vehicle (UAV) as submitted to the /v1/uav endpoint. This is your UAV telemetry you are submitting to SafeSky.
Yes | Altitude of the UAV in meters, based on GPS altitude AMSL. Value "-9999" means unknown. |
altitude_accuracy |
accuracy |
call_sign |
No | UAV call-sign. |
ground_speed |
turn_rate |
float |
vertical_rate |
icao24 |
No | Unique ICAO 24-bit address of the transponder in hex string representation. |
The Beacon model defines the structure of an aircraft beacon, as provided by SafeSky, to represent and describe all detected aircraft in the vicinity. This is the traffic as returned by SafeSky.
Yes | Altitude of the beacon in meters, based on GPS altitude AMSL. |
altitude_accuracy |
accuracy |
call_sign |
ground_speed |
turn_rate |
float |
vertical_rate |
No | Vertical rate in meters per second. |
beacon_type |
No | Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HELICOPTER, UAV, JET, etc. |
operation_area |
GeoJson |
No | When beacon_type is an ADVISORY, this GeoJson represents the polygon for the area of operation. |
remarks |
No | Free text comment when applicable. |
Example Payload:
"latitude": 50.70716,
"longitude": 4.36613,
"accuracy": 3645,
"call_sign": "ADVISORY TEST",
"last_update": 1764171645,
"altitude": 111,
"id": "my_advisory_id1"
