The UAV model defines the structure and attributes of an Unmanned Aerial Vehicle (UAV) as submitted to the /v1/uav endpoint. This is your UAV telemetry you are submiting to SafeSky.
Yes | Altitude of the UAV in meters, based on GPS altitude AMSL. Value "-9999" means |
altitude_accuracy |
accuracy |
call_sign |
No | UAV call-sign. |
ground_speed |
No | Direction of travel, specified in degrees counting clockwise relative to |
turn_rate |
float |
vertical_rate |
icao24 |
No | Unique ICAO 24-bit address of the transponder in hex string representation. See FAQs for more |
The Beacon model defines the structure of an aircraft beacon, as provided by SafeSky, to represent and describe all detected aircraft in the vicinity. This is the traffic as returned by SafeSky
Yes | Altitude of the beacon in meters, based on GPS altitude AMSL. |
altitude_accuracy |
accuracy |
call_sign |
ground_speed |
turn_rate |
float |
vertical_rate |
beacon_type |
operation_area |
GeoJson |
remarks |
"latitude": 58.88228,
"longitude": 5.51642,
"call_sign": "NOR303",
"last_update": 1764171642,
"altitude": 283,
"course": 63,
"ground_speed": 71,
"turn_rate": 0.06,
"beacon_type": "HELICOPTER",
"id": "478757"
"latitude": 50.72218,
"longitude": 4.615,
"call_sign": "LGL4EW",
"altitude": 6362,
"course": 108,
"ground_speed": 168,
"turn_rate": -0.06,
"beacon_type": "MOTORPLANE",
"id": "4D00C9"
"latitude": 50.70083,
"longitude": 4.02502,
"vertical_rate": 10,
"call_sign": "",
"transponder_type": "ADS-BI",
"last_update": 1764171647,
"altitude": 256,
"altitude_accuracy": 7,
"course": 43,
"ground_speed": 16,
"beacon_type": "PARA_MOTOR",
"id": "kmx87o80"
"latitude": 50.7756,
"longitude": 4.65264,
"call_sign": "CES261",
"altitude": 11399,
"course": 218,
"ground_speed": 278,
"id": "781EB7"
"latitude": 50.70716,
"longitude": 4.36613,
"accuracy": 3645,
"call_sign": "ADVISORY TEST WITH POLYGON",
"last_update": 1764171645,
"altitude": 111,
"operation_area": "{\"type\":\"Polygon\",\"coordinates\":[[[4.3948,50.6831],[4.3952,50.6832],[4.3958,50.6835],[4.3963,50.6838],[4.4072,50.6902],[4.4075,50.6903],[4.4081,50.6905],[4.4085,50.6907],[4.4092,50.691],[4.4096,50.6912],[4.4103,50.6915],[4.4106,50.6917],[4.411,50.692],[4.4113,50.6922],[4.4116,50.6925],[4.4118,50.6927],[4.412,50.693],[4.4121,50.6932],[4.412,50.6935],[4.4118,50.6937],[4.4115,50.694],[4.375,50.715],[4.3748,50.7153],[4.3746,50.7155],[4.3742,50.7158],[4.374,50.716],[4.3735,50.7162],[4.3733,50.7163],[4.3435,50.728],[4.3432,50.7281],[4.3426,50.7283],[4.3423,50.7284],[4.3416,50.7286],[4.3412,50.7287],[4.3405,50.7288],[4.3402,50.7289],[4.3395,50.729],[4.3392,50.729],[4.3385,50.7291],[4.3382,50.7291],[4.3376,50.729],[4.3373,50.7289],[4.3367,50.7287],[4.3365,50.7286],[4.336,50.7284],[4.3358,50.7282],[4.32,50.721],[4.3195,50.7208],[4.3193,50.7207],[4.3189,50.7205],[4.3187,50.7203],[4.3185,50.72],[4.3184,50.7198],[4.3182,50.7195],[4.3181,50.7193],[4.3948,50.6831]]]}",
"id": "my_advisory_id1_l2TZ"
"latitude": 58.88869,
"longitude": 5.63745,
"call_sign": "SAS92R",
"altitude": 9,
"course": 179,
"ground_speed": 44,
"id": "4ACA73"
"latitude": 50.89663,
"longitude": 4.18991,
"vertical_rate": -4,
"call_sign": "JAF11K",
"altitude": 3101,
"course": 51,
"ground_speed": 160,
"turn_rate": 0.06,
"id": "44B438"
"call_sign": "TRAFFIC UAV",
"last_update": 1764171644,
"altitude": 150,
"course": 180,
"ground_speed": 15,
"id": "my_uav_002_l2TZ"
"latitude": 50.7,
"longitude": 4.4,
"accuracy": 500,
"call_sign": "ADVISORY TEST WITH A POINT",
"altitude": 150,
"id": "my_advisory_id2_l2TZ"
"vertical_rate": 5,
"call_sign": "TEST UAV",
"altitude": 110,
"ground_speed": 10,
"id": "my_uav_001_l2TZ"
