The UAV model defines the structure and attributes of an Unmanned Aerial Vehicle (UAV) as submitted to the /v1/uav endpoint. This is your UAV telemetry you are submiting to SafeSky.
altitude int Yes Altitude of the UAV in meters, based on GPS altitude AMSL. Value "-9999" means unknown.
course int No Direction of travel, specified in degrees counting clockwise relative to true north.
icao24 string No Unique ICAO 24-bit address of the transponder in hex string representation. See FAQs for more details.
The Beacon model defines the structure of an aircraft beacon, as provided by SafeSky, to represent and describe all detected aircraft in the vicinity. This is the traffic as returned by SafeSky
altitude int Yes Altitude of the beacon in meters, based on GPS altitude AMSL.
beacon_type string No The type of the beacon. Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HAND_GLIDER, HELICOPTER, UAV, PARACHUTE, MOTORPLANE, JET, AIRSHIP, BALLOON, GYROCOPTER, FLEX_WING_TRIKES, PARA_MOTOR, THREE_AXES_LIGHT_PLANE, PAV, MILITARY, STATIC_OBJECT.
operation_area GeoJson No When beacon_type is an ADVISORY, this GeoJson represent the polygon for the area of operation
remarks string No Free text comment when applicable
        "latitude": 58.88228,
        "longitude": 5.51642,
        "call_sign": "NOR303",
        "last_update": 1764171642,
        "altitude": 283,
        "course": 63,
        "ground_speed": 71,
        "turn_rate": 0.06,
        "beacon_type": "HELICOPTER",
        "id": "478757"
        "latitude": 50.72218,
        "longitude": 4.615,
        "call_sign": "LGL4EW",
        "altitude": 6362,
        "course": 108,
        "ground_speed": 168,
        "turn_rate": -0.06,
        "beacon_type": "MOTORPLANE",
        "id": "4D00C9"
        "latitude": 50.70083,
        "longitude": 4.02502,
        "vertical_rate": 10,
        "call_sign": "",
        "transponder_type": "ADS-BI",
        "last_update": 1764171647,
        "altitude": 256,
        "altitude_accuracy": 7,
        "course": 43,
        "ground_speed": 16,
        "beacon_type": "PARA_MOTOR",
        "id": "kmx87o80"
        "latitude": 50.7756,
        "longitude": 4.65264,
        "call_sign": "CES261",
        "altitude": 11399,
        "course": 218,
        "ground_speed": 278,
        "id": "781EB7"
        "latitude": 50.70716,
        "longitude": 4.36613,
        "accuracy": 3645,
        "call_sign": "ADVISORY TEST WITH POLYGON",
        "last_update": 1764171645,
        "altitude": 111,
        "operation_area": "{\"type\":\"Polygon\",\"coordinates\":[[[4.3948,50.6831],[4.3952,50.6832],[4.3958,50.6835],[4.3963,50.6838],[4.4072,50.6902],[4.4075,50.6903],[4.4081,50.6905],[4.4085,50.6907],[4.4092,50.691],[4.4096,50.6912],[4.4103,50.6915],[4.4106,50.6917],[4.411,50.692],[4.4113,50.6922],[4.4116,50.6925],[4.4118,50.6927],[4.412,50.693],[4.4121,50.6932],[4.412,50.6935],[4.4118,50.6937],[4.4115,50.694],[4.375,50.715],[4.3748,50.7153],[4.3746,50.7155],[4.3742,50.7158],[4.374,50.716],[4.3735,50.7162],[4.3733,50.7163],[4.3435,50.728],[4.3432,50.7281],[4.3426,50.7283],[4.3423,50.7284],[4.3416,50.7286],[4.3412,50.7287],[4.3405,50.7288],[4.3402,50.7289],[4.3395,50.729],[4.3392,50.729],[4.3385,50.7291],[4.3382,50.7291],[4.3376,50.729],[4.3373,50.7289],[4.3367,50.7287],[4.3365,50.7286],[4.336,50.7284],[4.3358,50.7282],[4.32,50.721],[4.3195,50.7208],[4.3193,50.7207],[4.3189,50.7205],[4.3187,50.7203],[4.3185,50.72],[4.3184,50.7198],[4.3182,50.7195],[4.3181,50.7193],[4.3948,50.6831]]]}",
        "id": "my_advisory_id1_l2TZ"
        "latitude": 58.88869,
        "longitude": 5.63745,
        "call_sign": "SAS92R",
        "altitude": 9,
        "course": 179,
        "ground_speed": 44,
        "id": "4ACA73"
        "latitude": 50.89663,
        "longitude": 4.18991,
        "vertical_rate": -4,
        "call_sign": "JAF11K",
        "altitude": 3101,
        "course": 51,
        "ground_speed": 160,
        "turn_rate": 0.06,
        "id": "44B438"
        "call_sign": "TRAFFIC UAV",
        "last_update": 1764171644,
        "altitude": 150,
        "course": 180,
        "ground_speed": 15,
        "id": "my_uav_002_l2TZ"
        "latitude": 50.7,
        "longitude": 4.4,
        "accuracy": 500,
        "call_sign": "ADVISORY TEST WITH A POINT",
        "altitude": 150,
        "id": "my_advisory_id2_l2TZ"
        "vertical_rate": 5,
        "call_sign": "TEST UAV",
        "altitude": 110,
        "ground_speed": 10,
        "id": "my_uav_001_l2TZ"
