altitude int Yes Altitude of the UAV in meters, based on GPS altitude AMSL. Value "-9999" means unknown
The Beacon model defines the structure of an aircraft beacon, as provided by SafeSky, to represent and describe all detected aircraft in the vicinity.
Field Type Required Description id string Yes The unique identifier of the beacon. latitude double Yes Latitude in decimal degrees. longitude double Yes Longitude in decimal degrees. altitude int Yes Altitude of the beacon in meters, based on GPS altitude AMSL. altitude_accuracy int No Accuracy level of the altitude coordinate in meters. accuracy int No Accuracy level of the latitude and longitude coordinates in meters. call_sign string No Beacon call-sign, available only if the pilot has a public profile. ground_speed int Yes Current ground speed of the beacon, specified in meters per second. course int Yes Direction of travel, specified in degrees counting clockwise relative to the true north. status string No The current status of the beacon. Allowable values: INACTIVE, AIRBORNE, GROUNDED. last_update long Yes The time of the event in seconds since epoch at UTC-0. turn_rate float No Turn rate in degrees per second. vertical_rate int No Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent. beacon_type string No The type of the beacon. Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HAND_GLIDER, HELICOPTER, UAV, PARACHUTE, MOTORPLANE, JET, AIRSHIP, BALLOON, GYROCOPTER, FLEX_WING_TRIKES, PARA_MOTOR, THREE_AXES_LIGHT_PLANE, PAV, MILITARY, STATIC_OBJECT. operation_area GeoJson No When beacon_type is an ADVISORY, this GeoJson represent the polygon for the area of operation remarks string No Free text comment when applicable
