Yes | Altitude of the UAV in meters, based on GPS altitude AMSL. Value "-9999" means unknown |
altitude_accuracy |
accuracy |
call_sign |
No | UAV call-sign. |
ground_speed |
turn_rate |
float |
vertical_rate |
icao24 |
idstringlatitudedoublelongitudedoublealtitudeintaltitude_accuracyintaccuracyintcall_signstringground_speedintcourseintstatusstringINACTIVEAIRBORNEGROUNDEDlast_updatelongturn_ratefloatvertical_rateintbeacon_typestringUNKNOWNGLIDERPARA_GLIDERHAND_GLIDERHELICOPTERUAVPARACHUTEMOTORPLANEJETAIRSHIPBALLOONGYROCOPTERFLEX_WING_TRIKESPARA_MOTORTHREE_AXES_LIGHT_PLANEPAVMILITARYSTATIC_OBJECToperation_areaGeoJsonbeacon_typeADVISORYremarksstring
