altitude int Yes Height of the UAV in meters, based on GPS altitude AMSL. -9999 value means unknown
beacon_type string No The type of the beacon. Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HAND_GLIDER, HELICOPTER, UAV, PARACHUTE, MOTORPLANE, JET, AIRSHIP, BALLOON, GYROCOPTER, FLEX_WING_TRIKES, PARA_MOTOR, THREE_AXES_LIGHT_PLANE, PAV, MILITARY, STATIC_OBJECT.
operation_area GeoJson No When beacon_type is an ADVISORY, this GeoJson represent the polygon for the area of operation
remarks string No Free text comment when applicable
