altitude_accuracy |
accuracy |
call_sign |
No | UAV call-sign. |
ground_speed |
turn_rate |
float |
vertical_rate |
icao24 |
altitude_accuracy |
accuracy |
call_sign |
ground_speed |
turn_rate |
float |
vertical_rate |
beacon_type |
No | The type of the beacon. Allowable values: UNKNOWN,GLIDER, , , HELICOPTER, UAV, PARACHUTE, , , , BALLOON, , , PARA_MOTOR, THREE_AXES_LIGHT_PLANE, PAV, MILITARY, STATIC_OBJECT. |
operation_area |
GeoJson |
remarks |
