id
string
Yes
The unique identifier of the UAV.
latitude
double
Yes
Latitude in decimal degrees.
longitude
double
Yes
Longitude in decimal degrees.
altitude
int
Yes
Height of the UAV in meters, based on GPS altitude AMSL.
altitude_accuracy
int
No
Accuracy level of the altitude coordinate in meters.
accuracy
int
No
Accuracy level of the latitude and longitude coordinates in meters.
call_sign
string
No
UAV call-sign.
ground_speed
int
No
Current ground speed of the UAV, specified in meters per second.
course
int
No
Direction of travel, specified in degrees counting clockwise relative to the true north.
status
string
No
The current status of the UAV. Allowable values: INACTIVE, AIRBORNE, GROUNDED.
last_update
long
Yes
The time of the event in seconds since epoch at UTC-0.
turn_rate
float
No
Turn rate in degrees per second.
vertical_rate
int
No
Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent.
icao24
string
Unique ICAO 24-bit address of the transponder in hex string representation. See FAQs for more details
id
string
Yes
The unique identifier of the beacon.
latitude
double
Yes
longitude
double
Yes
altitude
int
Yes
Height of the beacon in meters, based on GPS altitude AMSL.
altitude_accuracy
int
No
accuracy
int
No
call_sign
string
No
Beacon call-sign, available only if the pilot has a public profile.
ground_speed
int
Yes
Current ground speed of the beacon, specified in meters per second.
course
int
Yes
status
string
No
The current status of the beacon. Allowable values: INACTIVE, AIRBORNE, GROUNDED.
last_update
long
Yes
turn_rate
float
No
vertical_rate
int
No
beacon_type
string
No
The type of the beacon. Allowable values: UNKNOWN,ADVISORY, GLIDER, TOW_PLANE, HELICOPTER_ROTORCRAFT, PARACHUTE, DROP_PLANE, HANG_GLIDER, PARA_GLIDER, POWERED_AIRCRAFT, JET_AIRCRAFT, UFO, BALLOON, AIRSHIP, UAV, STATIC_OBJECT.
operation_area
GeoJson
No
When beacon_type is an ADVISORY, this GeoJson represent the polygon for the area of operation
remarks
string
No
Free text comment when applicable
