altitude_accuracy |
accuracy |
call_sign |
No | UAV call-sign. |
ground_speed |
turn_rate |
float |
vertical_rate |
icao24 |
altitude_accuracy |
accuracy |
call_sign |
ground_speed |
turn_rate |
float |
vertical_rate |
beacon_type |
No | The type of the beacon. Allowable values: UNKNOWN,ADVISORY, GLIDER, TOW_PLANE, HELICOPTER_ROTORCRAFT, PARACHUTE, DROP_PLANE, HANG_GLIDER, PARA_GLIDER, POWERED_AIRCRAFT, JET_AIRCRAFT, UFO, BALLOON, AIRSHIP, UAV, STATIC_OBJECT. |
operation_area |
GeoJson |
remarks |
