altitude_accuracy |
accuracy |
call_sign |
No | UAV call-sign. |
ground_speed |
No | The current status of the UAV. Allowable values: INACTIVE , AIRBORNE , GROUNDED . |
turn_rate |
float |
vertical_rate |
icao24 |
altitude_accuracy |
accuracy |
call_sign |
ground_speed |
No | The current status of the beacon. Allowable values: INACTIVE , AIRBORNE , GROUNDED . |
turn_rate |
float |
vertical_rate |
beacon_type |
No | The type of the beacon. Allowable values: UNKNOWN ,ADVISORY , GLIDER , TOW_PLANE , HELICOPTER_ROTORCRAFT , PARACHUTE , DROP_PLANE , HANG_GLIDER , PARA_GLIDER , POWERED_AIRCRAFT , JET_AIRCRAFT , UFO , BALLOON , AIRSHIP , UAV , STATIC_OBJECT . |
operation_area |
GeoJson |
No | When beacon_type is an ADVISORY , this GeoJson represent the polygon for the area of operation |
remarks |
