altitude int Yes Height of the UAV in meters, based on GPS altitude AMSL.
beacon_type string No The type of the beacon. Allowable values: UNKNOWN,ADVISORY, GLIDER, TOW_PLANE, HELICOPTER_ROTORCRAFT, PARACHUTE, DROP_PLANE, HANG_GLIDER, PARA_GLIDER, POWERED_AIRCRAFT, JET_AIRCRAFT, UFO, BALLOON, AIRSHIP, UAV, STATIC_OBJECT.
operation_area GeoJson No When beacon_type is an ADVISORY, this GeoJson represent the polygon for the area of operation
remarks string No Free text comment when applicable
