altitude_accuracy |
accuracy |
call_sign |
No | UAV call-sign. |
ground_speed |
turn_rate |
float |
vertical_rate |
icao24 |
2. BeaconAircraft Model
altitude_accuracy |
accuracy |
call_sign |
ground_speed |
turn_rate |
float |
vertical_rate |
beacon_type |
remarks |
