| Field |
Type |
Required | Description |
altitudeAccuracy |
accuracy |
callSign |
No | UAV call-sign. |
groundSpeed |
lastUpdate |
turnRate |
float |
verticalRate |
icao24 |
altitudeAccuracy |
accuracy |
callSign |
groundSpeed |
lastUpdate |
turnRate |
float |
verticalRate |
beaconType |
