Field                      Type        Required Description
altitude int Yes Height of the UAV in meters, based on GPS altitude AMSL.
altitudeAccuracy int No Accuracy level of the altitude coordinate in meters.
callSign string No UAV call-sign.
groundSpeed int No Current ground speed of the UAV, specified in meters per second.
lastUpdate long Yes The time of the event in seconds since epoch at UTC-0.
turnRate float No Turn rate in degrees per second.
verticalRate int No Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent.
callSign string No Beacon call-sign, available only if the pilot has a public profile.
groundSpeed int Yes Current ground speed of the beacon, specified in meters per second.
beaconType string No The type of the beacon. Allowable values: UNKNOWN, GLIDER, TOW_PLANE, HELICOPTER_ROTORCRAFT, PARACHUTE, DROP_PLANE, HANG_GLIDER, PARA_GLIDER, POWERED_AIRCRAFT, JET_AIRCRAFT, UFO, BALLOON, AIRSHIP, UAV, STATIC_OBJECT.
