altitude int Yes Height of the UAV in meters, based on GPS altitude AMSL.
altitudeAccuracy int No Accuracy level of the altitude coordinate in meters.
callSign string No UAV call-sign.
groundSpeed int No Current ground speed of the UAV, specified in meters per second.
lastUpdate long Yes The time of the event in seconds since epoch at UTC-0.
turnRate float No Turn rate in degrees per second.
verticalRate int No Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent.
callSign string No Beacon call-sign, available only if the pilot has a public profile.
groundSpeed int Yes Current ground speed of the beacon, specified in meters per second.
beaconType string No
The type of the beacon. Allowable values: UNKNOWN, GLIDER, TOW_PLANE, HELICOPTER_ROTORCRAFT, PARACHUTE, DROP_PLANE, HANG_GLIDER, PARA_GLIDER, POWERED_AIRCRAFT, JET_AIRCRAFT, UFO, BALLOON, AIRSHIP, UAV, STATIC_OBJECT.
