altitudeAccuracy |
accuracy |
callSign |
No | UAV call-sign. |
groundSpeed |
lastUpdate |
turnRate |
float |
verticalRate |
altitudeAccuracy |
accuracy |
callSign |
groundSpeed |
lastUpdate |
turnRate |
float |
verticalRate |
beaconType |
No | The type of the beacon. Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HAND_GLIDER, HELICOPTER, UAV, etc. |
transponderTypestringADS-BIFLARMADS-B
