Field Type Required Description id string Yes The unique identifier of the UAV. latitude double Yes Latitude in decimal degrees. longitude double Yes Longitude in decimal degrees. altitude int Yes Height of the UAV in meters, based on GPS altitude AMSL. altitudeAccuracy int No Accuracy level of the altitude coordinate in meters. accuracy int No Accuracy level of the latitude and longitude coordinates in meters. callSign string No UAV call-sign. groundSpeed int No Current ground speed of the UAV, specified in meters per second. course int No Direction of travel, specified in degrees counting clockwise relative to the true north. status string No The current status of the UAV. Allowable values: INACTIVE, AIRBORNE, GROUNDED. lastUpdate long Yes The time of the event in seconds since epoch at UTC-0. turnRate float No Turn rate in degrees per second. verticalRate int No Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent.
Field Type Required Description id string Yes The unique identifier of the beacon. latitude double Yes Latitude in decimal degrees. longitude double Yes Longitude in decimal degrees. altitude int Yes Height of the beacon in meters, based on GPS altitude AMSL. altitudeAccuracy int No Accuracy level of the altitude coordinate in meters. accuracy int No Accuracy level of the latitude and longitude coordinates in meters. callSign string No Beacon call-sign, available only if the pilot has a public profile. groundSpeed int Yes Current ground speed of the beacon, specified in meters per second. course int Yes Direction of travel, specified in degrees counting clockwise relative to the true north. status string No The current status of the beacon. Allowable values: INACTIVE, AIRBORNE, GROUNDED. lastUpdate long Yes The time of the event in seconds since epoch at UTC-0. turnRate float No Turn rate in degrees per second. verticalRate int No Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent. beaconType string No The type of the beacon. Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HAND_GLIDER, HELICOPTER, UAV, etc. transponderType string No The type of transponder broadcasting the position. Allowable values: ADS-BI, FLARM, ADS-B, etc.
