Live UAV operations
1. Publish UAV
Description:Publishes one or many UAV position to the SafeSky platform. Optionally, it's returning a list of nearby aircraft for each UAV position within a default radius of 1000020000 meters. This response will not include the UAV you have posted.
  • x-api-key: <your_api_key>
Note:
rad int No 1000020000 Radius distance in meters from all UAV reference point (maximum 20,000 meters).
        "latitude": 50.7,
        "longitude": 4.2
        "id": "UAV3",
        "latitude": 50.8,
        "longitude": 4.1
        "id": "UAV4",
2. Get Aircraft
Endpoint: GET /v1/uav
Description
Use case
Request Headers
Notes
  • Search mode selection:
Query Parameters
rad int No 1000020000 Radius in meters from the reference point (maximum 20,000 m). Used only when viewport is not provided.
Response
Example Response
    "id": "hx-137105",
    "latitude": 63.41303,
    "longitude": 10.11205,
    "accuracy": 1852,
    "call_sign": "HWX137105",
    "last_update": 1766068287,
    "altitude": 231,
    "id": "096E2863",
    "latitude": 59.17081,
    "longitude": 9.5268,
    "beacon_type": "HELICOPTER",
    "vertical_rate": 45,
    "call_sign": "ROTORWING 30",
    "transponder_type": "ADS-BI",
    "last_update": 1766068285,
    "altitude": 450,
    "altitude_accuracy": 10,
    "course": 315,
    "ground_speed": 54,
