Live UAV operations
1. Publish UAV
  • x-api-key: <your_api_key>
Note:
Parameter Type Required DescriptionDefault DefaultDescription
alt_min int No 0
Filter all aircraft below the given altitude in AMSL meters. Zero0 means 'unused'. 0unused. alt_max int No 0 Filter all aircraft above the given altitude in AMSL meters. Zero0 means 'unused'. 0unused. return_nearby_traffic boolean No false Return information about aircraft traffic within proximity of the UAV positions. false
Additional query Parametersparameters when show_nearby_traffic = return_nearby_traffic=true:
rad int No 10000
Radius distance in meters from all UAV reference point (maximum:maximum 2000020,000 meters meters)). 10000 return_grounded_traffic boolean No false Include grounded beacons. false
        "latitude": 50.7,
        "longitude": 4.2
        "id": "UAV3",
        "latitude": 50.8,
        "longitude": 4.1
        "id": "UAV4",
2. Get Aircraft
Endpoint: GET /v1/uav
Description
Use case
Request Headers
Notes
  • Search mode selection:
Query Parameters
lat double No
0 Latitude in decimal degrees (4 decimal precision). Required for radius search. 0 lng double No 0 Longitude in decimal degrees (4 decimal precision). Required for radius search. 0 viewport string No — Bounding box to retrieve traffic, formatted as lat_min,lng_min,lat_max,lng_max (4 decimal precision is sufficient). — alt_min int No 0 Filter aircraft below the given altitude in AMSL meters. 0 means unused. 0 alt_max int No 0 Filter aircraft above the given altitude in AMSL meters. 0 means unused. 0 rad int No 10000 Radius in meters from the reference point (maximum 20,000 m). Used only when viewport is not provided. 10000 show_grounded boolean No false Include traffic with GROUNDED status if set to true. false
Response
Example Response
    "id": "hx-137105",
    "latitude": 63.41303,
    "longitude": 10.11205,
    "accuracy": 1852,
    "call_sign": "HWX137105",
    "last_update": 1766068287,
    "altitude": 231,
    "id": "096E2863",
    "latitude": 59.17081,
    "longitude": 9.5268,
    "beacon_type": "HELICOPTER",
    "vertical_rate": 45,
    "call_sign": "ROTORWING 30",
    "transponder_type": "ADS-BI",
    "last_update": 1766068285,
    "altitude": 450,
    "altitude_accuracy": 10,
    "course": 315,
    "ground_speed": 54,
