Live UAV operations
1. Publish UAV
Note:
ground_speed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
"latitude": 50.7,
"longitude": 4.2
"id": "UAV3",
"latitude": 50.8,
"longitude": 4.1
"id": "UAV4",
2. Get Aircraft
Endpoint: GET /v1/uav
Description
Use case
Request Headers
Notes
- If you have published UAVs via this API, they may appear in the response depending on the filters.
- Search mode selection:
- Use
viewportto retrieve traffic inside a map bounding box (recommended for map-based UIs). - Otherwise, use
lat+lngwithradfor a circular proximity search.
- Use
Query Parameters
lat |
No | Latitude in decimal degrees (4 decimal precision). Required for radius search. | 0 |
lng |
No | Longitude in decimal degrees (4 decimal precision). Required for radius search. | 0 |
viewport |
No | Bounding box to retrieve traffic, formatted as lat_min,lng_min,lat_max,lng_max (4 decimal precision is sufficient). |
alt_min |
No | Filter aircraft below the given altitude in AMSL meters. 0 means unused. |
0 |
alt_max |
No | Filter aircraft above the given altitude in AMSL meters. 0 means unused. |
0 |
rad |
No | Radius in meters from the reference point (maximum 20,000 m). Used only when viewport is not provided. |
10000 |
show_grounded |
boolean |
No | Include traffic with GROUNDED status if set to true. |
false |
Response
Example Response
"id": "hx-137105",
"latitude": 63.41303,
"longitude": 10.11205,
"accuracy": 1852,
"call_sign": "HWX137105",
"last_update": 1766068287,
"altitude": 231,
"id": "096E2863",
"latitude": 59.17081,
"longitude": 9.5268,
"beacon_type": "HELICOPTER",
"vertical_rate": 45,
"call_sign": "ROTORWING 30",
"transponder_type": "ADS-BI",
"last_update": 1766068285,
"altitude": 450,
"altitude_accuracy": 10,
"course": 315,
"ground_speed": 54,
